26 Mar 2025
12:51 PM
27 Mar 2025
08:18 AM
Hi Experts,
I have successfully configured DB2 monitoring with TCPIP port. Everything is working fine. But when i try to configure it for SSL port, I'm ending up with same error every time.
Com.ibm.db2.jcc.am.SqlNonTransientConnectionException: [jcc][t4][20162][14259][4.32.28] Connection failed: could not establish a SSL connection with the server. The connection has been configured to use hostname validation and the servers TLS certificate does not contain a hostname or IP address which matches the value configured by the client. ERRORCODE=-20576, SQLSTATE=08001
I'm not sure which keystore to verify in first place.
Need help from experts who enabled DB2 monitoring using SSL.
