Databricks monitoring through Dynatrace
Chandnipatel
Participant
Since we can monitor the Databricks by Dynatrace as a OneAgent extension, apart from the listed metric list in the document ( https://www.dynatrace.com/hub/detail/databricks-1/ ) below can we also monitor parent and child notebooks which is a part of Databrick jobs that run over schedule time on it.
Use case : The client has multiple jobs running on Databricks that are getting successful. However, while checking the data/output, it seems mismatched or incorrect because of the child notebook failure inside the parent notebook.
 Note: They are getting notified by the scheduler in case of parent notebook failure but not if the child notebook fails
0 REPLIES 0
