Deploying custom-built python based extensions in a Dynatrace Managed Environment
priyankayv
Frequent Guest
Are there documented steps or guidelines for deploying custom-built extensions to a Dynatrace managed environment?
5 REPLIES 5
AntonPineiro
Are you talking to OneAgent custom extension? ActiveGate extension?
Best regards
Have you check OneAgent extensions tutorial?
Best regards
priyankayv
Frequent Guest
I checked it, previously, there was an option under settings-> Monitored Technology -> Monitored Technology > Add OneAgent Extension which is not shown now.
You are right. I think as another Extension 2.0.
Maybe before method was only for Extension 1.0
Best regards
