Failover mode metric for MS SQL extension
Mayuri77
Newcomer
The MS SQL extension to gather a metric that could detect and alert when a cluster fails over to another node. The current "failover mode" metric just gives a status of manual or automatic and does not fit our use case.
Esam_Eid
Pro
Hi @Mayuri77,,
What about the MSSQL logs? Were you able to capture the failover from logs and create log metric?
Regards
Esam Eid
