03 Apr 2025 05:44 AM
Hi ,
I am working on an CUSTOM EXTENSION DEVELOPEMENT : SNMP extension for Cisco devices and running the snmpwalk command on ActiveGate. When I execute the command, I receive multiple responses for a single OID. If it were a single response, I could map it as a single metric. However, since multiple responses are returned, I would like to understand how to properly import and structure them as metrics in Dynatrace.
Could you please advise on:
05 Apr 2025 06:58 PM
in this case i will try you to handle the return values as dimensions (with eventually the use of filters) and the metric value as a count.
17 Apr 2025 10:26 AM
Hi Yanezza,
Thanks a lot for your suggestion I really appreciate your input!
You mentioned using the returned SNMP values as dimensions and treating the metric value as a count possibly with filters. However, after some deeper testing I’ve run into a few limitations I’d like to share to check if you might have any alternate ideas.
My Use Case
I’m working on a Dynatrace SNMP Extension 2.0 to collect metrics for BGP peer admin status from Cisco routers. The relevant SNMP table is:
OID for Admin Status: .1.3.6.1.2.1.15.3.1.3
OID for Peer AS Number: .1.3.6.1.2.1.15.3.1.9
When I run:
snmpwalk -v2c -c 'communitystring' 10.154.192.51 .1.3.6.1.2.1.15.3.1.3
I get multiple responses like this:
SNMPv2-SMI::mib-2.15.3.1.3.*.*.*.* = INTEGER: stop(2)
SNMPv2-SMI::mib-2.15.3.1.3.*.*.*.* = INTEGER: start(1)
So the peer IPs (like *.*.*.*) are embedded in the OID suffix/index.
❗Challenges
Property Walk is disabled in my environment (customer policy), so I can’t use that to auto-discover or assign dynamic dimensions.
Dynatrace SNMP Extension 2.0 doesn’t currently allow me to:
Extract the index values (e.g., IP from OID) as a dimension automatically
Assign dimensions dynamically based on SNMP response without a walk
Due to these constraints, I’m currently using a preprocessing script that:
Runs a manual walk
Extracts peer IPs from OIDs and matches them with their status
Generates static YAML metric entries for each peer with dimensions like peer_ip and asn
This works, but it’s static per device and doesn’t scale well.
❓My Ask
Given these limitations, do you think there’s any workaround within Extension 2.0 that could help simulate what you suggested? Maybe something creative with custom mapping or using the OID suffix as part of the key?
I’d love to hear your thoughts or any tricks you might have up your sleeve!
Thanks again for your time and input 🙏
Best regards,
Kranthi
