12 Mar 2025
04:02 PM
13 Mar 2025
07:13 AM
Hello community,
We need to identify the exact names of the Message Flow Accounting and Statistics Records metrics so we can incorporate them into our Dynatrace dashboards.
We have tried to find the corresponding metrics within Dynatrace but haven’t been able to locate them.
Here are some of the specific metrics we are looking for:
As far as we understand, IBM environments—especially those running middleware such as IBM MQ, IBM Integration Bus (IIB), or IBM WebSphere—should have relevant metrics available in Dynatrace. However, we are aware that the metric names might not exactly match those from IBM’s documentation and that Dynatrace may append a unique identifier to them.
Reference link to the IBM documentation for context:
https://www.ibm.com/docs/en/app-connect/13.0?topic=data-message-flow-accounting-statistics-records
Is there a way to determine the exact metric names as they appear in Dynatrace? Any best practices or guidance for mapping these IBM statistics to Dynatrace metrics would be highly appreciated.
Thanks in advance!
