08 Jun 2018
02:33 PM
28 Jun 2021
01:12 PM
I want to add additional metrics for an unsupported device using the Dynatrace API
https://www.dynatrace.com/support/help/dynatrace-a...
It's more an appliance, so there is no oneagent on there. I could write some code in some runtime to fetch these metrics (remotely) and send this as a json payload to Dynatrace. But that's not really a 'plugin' then.
What I understand of plugins (https://dynatrace.github.io/plugin-sdk/readme.html... is that they are executed by the oneagent and gather metrics of that particular host.
So I wonder if there is something like a remote plugin to gather metrics from something that does not have a oneagent. Using the API's to create a custom device and push metrics. But all nicely controlled as a plugin from with Dynatrace. A bit like the Monitor plugins of AppMon which were executed from a collector. Maybe with Dynatrace it can be executed on a regular basis from within the private security gateway.
I read about the F5-firewall monitor initiative. It's something like that which I need but then for other technology.
11 Jun 2018 09:02 AM
Hi Bert,
Remote Plugins which are running from a security gateway will be coming later this year. We're indeed busy with a few plugins already using an internal EAP, one of which being f5, and another being DataPower.
Mike
11 Jun 2018 01:50 PM
Hey Mike,
Thanks for the info. We are looking into creating one for Netscaler.
Will these remote plugins also be written in Python? Just a matter of already starting implementing something as a separate process and no need for a lot of rewriting afterwards.
Kr,
Bert
11 Jun 2018 01:59 PM
Netscaler is currently on top of our list and will most likely be finished before GA.
Yes, it is in Python.
Mike
26 Feb 2019 07:12 PM
@Michael L. Do you have an update on the Netscaler plugin and if it is available?
26 Feb 2019 07:23 PM
Hi, it is currently in EAP, you can reach out to your account manager for access.
06 Aug 2018 09:51 PM
Hello everyone;
I'm trying to install the datapower plugin for Dynatrace
The documentation says that from the version Windows ActiveGate version 1.147+.
I installed the Dynatrace-Security-Gateway-Windows-1.149.165 but I don't see the button: Upload ActiveGate plugin
Soo I have add the parameter: REMOTE_PLUGIN_SHOULD_INSTALL="true"
Remote Plugin Agent service:
I'm also installing the activegate 147.186 and no have this parameter activated.
Regards.
06 Aug 2018 10:46 PM
Apparently whoever shared it with you did not enable the required feature flag. Please reach out to extensions@dynatrace.com with the url to your environment and where you got the plugin from and we will arrange it.
Kind regards,
Mike
06 Aug 2018 11:30 PM
Hola Michael,
Thank you very much.
I'm going to request it.
_RGuerrero
