Issue with Citrix NetScaler ADC extension and self-signed certs
LordNykkon
Participant
I'm unable to monitor our NetScaler ADCs with the official extension due to an issue with Python and the self-signed SSL certs generated by the ADCs.
The dt.system.events for the extension show the following messages when enabling a configuration:
The ActiveGate logs are as follows (obfuscated server IP for security):
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][out]2024-05-28 11:56:08,237 [INFO] dynatrace_extension.extension (ThreadPoolExecutor-0_0): query method started for Netscaler nitro API.
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][out]2024-05-28 11:56:08,237 [INFO] dynatrace_extension.extension (ThreadPoolExecutor-24_0): Polling Netscaler endpoint: "https://*********"
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][out]2024-05-28 11:56:08,237 [INFO] dynatrace_extension.extension (ThreadPoolExecutor-24_0): Login: "https://*********/nitro/v1/config/login"
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][out]2024-05-28 11:56:08,253 [INFO] dynatrace_extension.extension (ThreadPoolExecutor-0_0): No events were returned
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err]2024-05-28 11:56:08,253 [ERROR] dynatrace_extension.extension (ThreadPoolExecutor-0_0): NetscalerException('Error connecting to Netscaler: "https://*********" : "(\'Connection aborted.\', ConnectionResetError(10054, \'An existing connection was forcibly closed by the remote host\', None, 10054, None))"')
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err]2024-05-28 11:56:08,253 [ERROR] api (ThreadPoolExecutor-0_0): Error running callback Method=netscaler_query: NetscalerException('There were errors when connecting to Netscaler endpoints, check the ActiveGate logs for details')
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err]Traceback (most recent call last):
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err] File
"C:\ProgramData\dynatrace\remotepluginmodule\agent\runtime\extensions\python_venvs\com.dynatrace.extension.netscaler_2.0.2\lib\site-packages\dynatrace_extension\callback.py", line 63, in __call__
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err] result = self.callback(*self.callback_args)
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err] File "C:\ProgramData\dynatrace\remotepluginmodule\agent\runtime\extensions\python_venvs\com.dynatrace.extension.netscaler_2.0.2\lib\site-packages\netscaler\__main__.py", line 77, in netscaler_query
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err] raise NetscalerException(
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][err]netscaler.netscaler_api.NetscalerException: There were errors when connecting to Netscaler endpoints, check the ActiveGate logs for details
[404422b1-6988-3fc2-9b8e-cd514f1ccb9b][4173992537127303033][7572][out]2024-05-28 11:56:08,612 [INFO] api (ThreadPoolExecutor-1_3): Sent 1 metric lines to EEC: [MintResponse(lines_ok=1, lines_invalid=0, error=None, warnings=None)]
I ran into this problem a few months ago when I was tasked with scripting some reports using the Nitro API. I wrote a client that's similar to yours and would get the following error message when trying to use a standard requests.Session() with the verify=False flag:
After HOURS of researching and troubleshooting, I discovered that its due to a mismatched hostname during the SSL handshake. I found a workaround by sub-classing requests.adapters.HTTPAdapter, setting the check_hostname flag to False, then mounting the adapter to the requests.Session object I passed into the Netscaler class as shown below:
import requests
from requests.adapters import HTTPAdapter
import ssl
import logging
from netscaler.nitro_api import Netscaler
logging.basicConfig(level=logging.DEBUG)
# 1. Subclass HTTAdapter and configure the SSL context
class SSLAdapter(HTTPAdapter):
    def init_poolmanager(self, *args, **kwargs):
        ssl_context = ssl.create_default_context()
        ssl_context.set_ciphers('DEFAULT@SECLEVEL=1')
        ssl_context.check_hostname = False
        ssl_context.minimum_version = ssl.TLSVersion.TLSv1_2
        kwargs["ssl_context"] = ssl_context
        return super().init_poolmanager(*args, **kwargs)
# 2. Create a Requests Session and mount the SSLAdapter
this_session = requests.Session()
this_session.verify = False
this_session.mount('https://', SSLAdapter())
# 3. Create the Netscaler client and pass in the Session along with the IP
nitro = Netscaler(session=this_session, ip="<server_IP>")
# 4. Login to acquire authentication cookie for the Session
logged_in = nitro.login(u_name="NITRO_USERNAME", pw="NITRO_PASSWORD")
print(logged_in)
The extension's code (...\site_packages\netscaler\netscaler_api.py) already has logic for handling when Verify SSL Certificates is disabled in the UI configuration:
Could you add the class for the SSLAdapter above and have it be mounted to the session (s) if config.verify=False?
Example:
        ssl_context.options |= 0x4
class NetScaler():
    def __init__(self, config: NetscalerConfig):
        s = requests.session()
        self.auth = {'username': config.user, 'password': config.password}
        s.verify = config.verify
        if not s.verify:
            s.mount('https://', SSLAdapter())
        self.session = s
 This would allow users with self-signed certs to connect to the Citrix NetScaler ADCs and get them into Dynatrace!
4 REPLIES 4
jegron
DynaMight Champion
DynaMight Champion
Hi @LordNykkon ! Very nice investigation. Could you open a support case ?
Observability Engineer at Phenisys - Dynatrace Professional
I brought it up to our account reps and I think they are already escalating it internally. Thank you for the reply though.
brayden_neale
Dynatrace Helper
Dynatrace Helper
Hi @LordNykkon
Thanks for the detailed explanation and solution provided!
I have implemented and tested this in a new version of the Dynatrace NetScaler extension which will be released to the Hub shortly.
This has saved me a lot of time and effort with future support tickets. Before this support guidance was to require customers to enable the netscaler default profile and actually bind ciphers to the internal_frontend_service.
I just updated to the latest version (2.2.1) and can confirm the patch works. All our NetScalers are pulling info now. Thank you!
