04 Dec 2024 12:24 AM
This is in the context of the extension synthetic-sftp-monitor.
A SFTP endpoint using an AWS Transfer based endpoint needs to be monitored. But username/password based authentication for the Transfer endpoint has been disabled. The endpoint exclusively uses SSH key-based authentication.
Given the above scenario, How can Synthetic SFTP monitor be used to monitor the SFTP endpoint?
Please advise!
04 Dec 2024 03:08 AM - edited 04 Dec 2024 03:09 AM
Hello @dyn98007 ,
This extension supports both basic authentication and key authentication. You can see the relevant section in the extension documentation below.
Key Configuration
If the connection to the SFTP server requires a security key, provide the details here.
The solution we implemented was creating a credential vault with the type `username and password`. In the username field, I entered the actual username, and in the password field, I pasted the private key entire content. This worked for us.
It might be worth trying.
Regards ,
Akhil Jayendran
04 Dec 2024 05:41 AM - edited 05 Dec 2024 01:38 AM
Hi @Akhil-Jayendran :
Thanks for the comment...Can I know version number of the SFTP Extension that was used?.
