10 Mar 2025
08:19 PM
11 Mar 2025
07:54 AM
Hi There,
I am working on migration task on our Custom DB Query written in python on Dynatrace managed using extension 1.0 to Extension 2.0 - SQL Data Source. Though it is successful, I wasn't able to define it as group and sub-group in our scenario. Seeking for a help in what SQL query should I define in the group level, in case I re-define 2nd, 3rd and 4th group in below example as a sub-group. Such that I can make use of same extension up to 100 metrics. Otherwise, I will be limited to 10 metrics only (assume if only one metric defined against each sql query in a group and no sub-group exist). Note, where possible I tried to merge multiple queries into one single queries. In below example, assume I cannot merge queries into one single sql statement. I do make use of dimension and multiple keys where possible. These queries are specific to application tables and not any generic that can be used across the database or server.
Thanks and Regards,
Darshan Doshi
