27 Jul 2025
05:35 AM
29 Jul 2025
07:55 AM
i am able to extract problems for last 3 hrs with nextpagekey . all looks fine including refresh . but when i publish in power bi service . it throws "cannot schedule direct query" . How to mitigate that including next page key
28 Jul 2025 12:52 AM
@Vijayt I see currently import mode is only supported , you might need to switch the connection from Direct Query to Import Mode in Power BI connection settings
https://docs.dynatrace.com/docs/shortlink/power-bi-extension#limitations
https://www.phdata.io/blog/import-vs-direct-query-power-bi/
31 Jul 2025 03:39 AM
i dont see connection property option import mode
