remote unix memory usage shows wrong
sampathkumar
Participant
we have installed remote unix plugin in rhel 5/6 versions and remote_unix.physical_memory_used_percent  is considering only the free but not the cached ones.  free memory should be actual free+ cached ones but this metric shows only free which will always be 1 1 or 2%  as cache use all memory as much as possible. it leave us difficult to monitor actual available memory ?
Is there any workaround any new version remediate this ?
3 REPLIES 3
JamesKitson
Dynatrace Guru
Dynatrace Guru
Hello, we actually do have a new version being validated by a few customers currently that has the buffer/cache changes included. Keep an eye out on the Hub and hopefully it should be out this week.
Basically it implements this: https://access.redhat.com/solutions/406773
Thanks for the update.
is it released ?
