07 Mar 2022
10:17 PM
18 Mar 2022
05:20 AM
Karolina_Linda
I setup a Mobile iOS Application on Dynatrace, created an access token with all scopes.
Then I setup the Dynatrace add-on for Splunk using my account + access token. I also setup all 3 Inputs (Entities, problems and timeseries metrics - all using the "dynatrace" index.)
The dashboard / graphs are populating within Dynatrace for the Mobile app, and I was expecting to get this data in Splunk.
Communication between the Splunk add-on and Dynatrace is working fine, BUT I'm not getting any useful information.
Am I missing something or does the add-on not support this?
The data i'm getting looks like this:
sourcetype=dynatrace:problem
{"dynatrace_server":"https://gce<xxxx>.live.dynatrace.com"}
sourcetype=dynatrace:entity
{"customizedName": "MyApp", "discoveredName": "xxxxxxx-xx-xxxx-xxxx-xxxxxxx", "displayName": "MyAppp", "endpoint": "applications", "entityId": "MOBILE_APPLICATION-xxxxxxxxxx", "firstSeenTimestamp": 1646142830047, "fromRelationships": {}, "lastSeenTimestamp": 1646719754020, "mobileOsFamily": ["IOS"], "tags": [], "timestamp": 1646719754.02, "toRelationships": {}}
