What is the best option to Integrate Dyntrace Managed and SNOW Resolver Group?
kjayaraman6
Participant
EG: DB alerts should go to DBA support etc. Should we use Tag or Altering Profile ? Looks like it should be a combination of both
4 REPLIES 4
nj_njoku
Inactive
Hi Kamal,
Alerting Profiles in Dynatrace are created based on Tags and then the alerting profile is included in the configuration to integrate with SNOW so yes it is a combination of both.
See links below that will assist in the setup
Dynatrace integration with SNOW
https://www.dynatrace.com/support/help/problem-detection/problem-notification/how-do-i-configure-int...
Alerting Profiles
https://www.dynatrace.com/support/help/problem-detection/problem-notification/how-can-i-filter-probl...
NJ
kjayaraman6
Participant
Could someone help with the workflow for the below requirement
Lets assume I have two Application servers running WebSphere, If I do autotagging, How do I use tagging to identify the resolvergroup in SNOW.
EG: ApplicationServer A Websphere issues should go to resolver group1 and
ApplicationServer B Websphere issues should go to resolver group2
Hi Kamal,
did you resolved this issue? I have the same question.
BR,
Sonia
kjayaraman6
Participant
Hi .how is this achived
