Agent Recorder how to check an OS application is running?
sylvian_lam1
Organizer
I'd like to check the existence of a window task(as shown in task manager) within the Recorder script, otherwise start it if the window task is not found. I have to use the window title to check because multiple windows are using the same process name. Is there any method or syntax to do that?
Thanks.
Sylvian
3 REPLIES 3
sylvian_lam1
Organizer
Hi, I found the solution 🙂
TApp can do.
The documentation for TApp is at TApp Object. Thanks!
yuriy_look
Inactive
