Alert for occurrence of a URL not working.
bob_zins
Helper
I'm trying to setup an alert to trigger when there is an occurrence of an error page but it is not working for me.
First I set up the URL as a defined URL. ex http://appname.com/time/forms/error.asp..
Then I created a new alert and added a filter dimension for software service and operation. I then added a monitored metric for operation count with a value condition to be > 0.
In the operation dimension I tried http://appname.com/time/forms/error.asp.. and when that did not work I tried *appname.com/time/forms/error*.
Any thoughts, I assumed this would be really simple.
9 REPLIES 9
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Bob,
If you create a DMI with the operation and add the metric operations, do you see data?
In other words, I am trying to see if the operation (Error page) is seen by the CAS.
Harshal.
bob_zins
Helper
Yes, see below.
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Bob,
Can you also please post the alert config screenshot from the RUM Console?
bob_zins
Helper
Here you go. In this example I wild carded the front and end. But I also tried the full URL; http://appname.com/time/forms/error.asp
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Bob,
Can you please add the dimension "Software service" and "operation", in the Monitored Dimensions section?
Harshal.
bob_zins
Helper
Like this?
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Bob,
Yes exactly like that. Do you see the alerts triggering now?
bob_zins
Helper
After adding monitored dimensions the alert still did not trigger. I think I will try dropping the wild card from the operation filter and put in the complete operation name,.
sangeetha_mitta
Organizer
Can anyone tell us how to get an alert when an application http Url goes down when the customers are accessing.. In APPMON
