Alert is not triggering - DCRUM
rsharma8
Participant
Hi team,
I have configured one alert for condition - Operation time exceeds 200% of benchmark value
I have selected below :
Dimension :  Software Service
Dimension Filter :  Software Service -  xyz.abc.com WEB VIP HTTPS 48022 ( as this SS was mentioned by app team for alert configuration)
Is Front end tier : Yes
Monitored Metrics: Opeartion Time
Baseline Conditions: current value is greater than 2 times baseline value.
But this alert is not triggering for some reason. Please provide your suggestions.
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Rashmi,
I am assuming that the operation time for the software service did indeed exceed the 200% of the benchmark value, right?
If so, can you please check  your alert definition to make sure it includes one of the following combination of dimensions?
  • Software service – server IP address
  • Software service – server IP address – operation
  • Software service – server IP address – task
  • Software service – server IP address – module
  • Software service – server IP address – service
  • Reporting group – software service – server IP address – operation
  • Application – software service – server IP address – operation
  • Transaction – software service – server IP address – operation
  • Tier – software service – server IP address – operation
  • Site – software service
  • Area – software service
  • Region – software service
  • WAN link name – software service
See this link
Hope this helps,
Harshal.
Thank you Harshal for your response. I will try this and will let u know.
