Application Turns metric
Does anyone know whether DC RUM is capable to show application turns metric ? If yes, what's the metric name ?
Cheers
Krzysztof_Ziemi
Dynatrace Pro
Dynatrace Pro
Application turns are represented by the Number of Operations metric in the Generic TCP with Transactions analyzer. The way how transaction analysis works is that it looks at pairs of request-response, regardless of whether it's first or last or middle part of the session. Analyzer assumes that a request from the client has to be accompanied by a response from the server and that response may have more than one packet. Timeout for the response is 5 min default, can be changed.
Thanks Kriz Z. I will follow up to check it out. Is the metric name "Operations".
