Application is showing the same IP for all users
akshay_shinde2
Inactive
Hello Experts,
We noticed that one of our HTTPS application is showing the same IP for all users.
Other application are showing associated user IP’s correctly only this application has a problem.
Does anybody encountered with such issue?
BR,
Akshay
tore_davidsen
Newcomer
Probably you are capturing this behind an LB, and the address you see is the inside of the LB. Have you examined the traffic (a.k.a. packet dump)?
Hi Tore,
Basically we do a ping to application URL (Local machine) & whatever IP we are getting that we add to the DCRUM configuration. We followed the same thing here as well.
However when we pinged the same URL from the machine where application is hosted we got different IP. (This time machine & application are from same DC)
We are capturing this before the LB because sniffing is done before the firewall.
What I need to check in tcpdump?
BR,
Akshay
