Bandwidth speed
Ari_Knox
Dynatracer
Dynatracer
Is there a new option for setting the incoming and outgoing speed for user defined links? It still works using nvregion but I do not want to show customer the old style reports.
Radoslaw_Szulgo
Dynatrace Leader
Dynatrace Leader
Setting speed for UDL (user defined link) can be done in location-*.config file
See the example in "locations-sample.config" file in config directory of CAS installation.
Technical Product Manager,
Dynatrace Managed expert
marco_mannucci2
Inactive
Is this the only place to set the speed? And if so is it possible to populate this file from the existing configuration? We don't use the config file but simply add sites directly via the settings -  sites gui.
