CAS launch to RUM Console using IP rather than FQDN is causing issues. Can this be changed?
keith_young1
Newcomer
The 12.4 solution is fully configured to use https (Customer Signed Certs) but when accessing the CAS and navigating to Setting -> Monitoring -> RUM Console; the spawned connection presents as:
https://IP:4182/cablebox
This presents the IE Warning Page which cannot be handled by the Third Party 'EDGE enPortal' implemented in the environment.
3 REPLIES 3
keith_young1
Newcomer
That should have read
https://IP:4183/cablebox/....
alasdair_patton
Dynatrace Pro
Dynatrace Pro
Hi Keith
If you navigate to http://cashostname/DiagConsole#/userprops
search for CONSOLE_WEBSTART_HOST and update it to your hostname that should solve your issue.
Regards
Alasdair
Thanks Alasdair
This configuration setting has resolved the issue.
