Create DMI with Multiple Charts for Dimensions
brett_b2
Inactive
Hello everyone,
I'm not sure how to do this, but I feel that it should be possible:
My client would like one chart that shows Total Bytes, Total Bytes from a particular Software Service, and then Total Bytes from a particular set of Remote Host Names all overlayed on each other
The problem is that when I create the chart with Total Bytes of a particular Software Service, I can't seem to create another line on the graph representing the Total Bytes without that filter applied
Do I just have to use multiple sections?
Thanks!
3 REPLIES 3
brett_b2
Inactive
The other Guardian on-site, Joel Butzow, was able to plot two of the three lines on each other using the Benchmark Data tab
I have a feeling we'll be limited to just two on one graph
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Filter is applied to all series in the chart so you need to create separate chart with different or none set of settings.
brett_b2
Inactive
Darn, that's what I figured
Thanks Adam!
