Creating a VBA script to automate site management
chloe_aubras
Newcomer
I would like to know if it is possible and how to create a VBA script to convert a file containing the following syntax:
MyLocation = X.X.X.X-X.X.X.X
Mylocation.area = MyArea
Myarea.region = MyRegion
And turn it into a .csv file simplified like in attachment.
C.A.
4 REPLIES 4
pierrick_planc2
Inactive
Anything is possible in the scripting world, so you can absolutely do that.
However as for the detailed parsing algorithm and file generation, I don't think you'll find this here, though it's not very difficult it is time consuming.
May I ask why you want this in VBA ?
chloe_aubras
Newcomer
I want this VBA script because every 3 months sites are updated within our organization (new ip adresses, new area,...) and this is very constraining to add them manually every time.
Hi again,
I understand the reason, my question was really about the choice of technology.
chloe_aubras
Newcomer
Sorry, my mystake, infact the type of script doesn't matter, as it allows me to get the result I need.
I just logically thought about VBA script because at the end I want a .csv file.
