DCRUM 2017 Set Speed Dial: Favorites as default homepage for all users?
travis_booth
Helper
Trying to edit servletsmenu-420-rtm.properties to set the Speed Dial: Favorites as homepage for all users.
Currently set to: *main.Index=discovery dashboard_link
What do I change main.Index to so that all users homepage is Speed Dial: Favorites? Thanks!
4 REPLIES 4
travis_booth
Helper
Solved my own issue. Change to the following in servletsmenu-420-rtm.properties.
*main.Index=myIndexPage
myIndexPage.Label=Favorites
myIndexPage.Index=dashboard?panel_tabItem=favorites
This solution will also work for any URL you want to use. Just change myIndexPage.Index= to whatever you want.
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
Hello, Do you know if it works with NAM 2018. I have tried the config on a specific URL as home page, but it doesn't work.
JLL
travis_booth
Helper
Hey Jean, I have not tried on NAM 2018 sorry.
