DMI Integration with Dynatrace WEB Dasboard
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
Is there a way to drilldown from AHS dmi report to Dynatrace Web Dashboard? (if possible with the same filter of Application and Transaction)
JLL
4 REPLIES 4
david_alonso
Dynatrace Pro
Dynatrace Pro
I've done to link the dashboards I want (saved dashboards) it if with a custom link on the DMI:
Use as URL:
http://[DTSERVER]/webstart/Client/client.jnlp
(change for https if https is eanble on DT)
And As argument:
argument=-reuse&
argument=-dashboard&
argument=online://[Source o DT SERVER]/[Dashboard Name]
For example:
http://localhost:8020/webstart/Client/client.jnlp?argument=-reuse&argument=-dashboard&argument=online://par121155n02/easyTravel+Busine
I hope it helps.
forgot to tell you, you can create as many links as application are and as many dashboards on DT as applications are. Then in your DMI you create as many links as applications and with a contion to show the link based on the application name(Application == "your application") and on the link you put the DT dashboard name that macth with the application
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
Hello David,
The integration with dynatrace webstart client works as design.
My request concerns DMI integration with Dt web Dashboard : https://<DTServer>:9911
Is it possible ?
JLL
you can do the same procedure, but in this case you use the URL that the share this wiew (that you will find in your web dashboard) give you. You copy this URL and you place it on the custom link on the CAS, on your application health report
