DMI Report Help Please
sid_govindu
Dynatrace Organizer
Dynatrace Organizer
Hi All,
One of our client is trying to create a DMI report that mimics what they already have in EP,
Two Metrics - in EP: Stacked Columns and lines
But in DMI, when Stacked Columns is selected, the lines are changing to stacked lines and the customer requires them to be lines.
Need the below to look like the above.
Sid
3 REPLIES 3
Sid,
I will work with the dev team to resolve that as a bug. I agree with you that using "stacked lines" makes any sense here. I will let you know if the fix will be available in 12.3.3 service pack.
Cheers,
sid_govindu
Dynatrace Organizer
Dynatrace Organizer
Yep, that would be great, thanks Sebastian.
The solution to this problem will be available in 12.3.3 and in 12.4: for stacked columns on one axis, the lines on the other axis will not be stacked.
