DMI Report: Set a dimension using a metric (i.e. custom dimensions)
dconnett
Contributor
I am having trouble getting some data from the DMI.
Essentially we are trying to differentiate how many bytes on the wire are HTTP Succeeded hits vs. HTTP 4xx and HTTP 5xx errors.
I would normally try to define the dimension of the report something like "HTTP Category" and have the metric set as Total Bytes. Unfortunately no such category exists, and I cannot figure out how to do this only using the metrics.
Does anyone have any insight to this problem?
Thanks!
Dave
dconnett
Contributor
I figured out a solution to use case, but it did not involve custom Dimensions.
The ADS actually has extra dimensions, one of which is the HTTP Response Code. I set that as the main dimension, and broke it down by Bytes and we got our answer.
Thanks anyway!
