DMI dimenstion - storage source
sylvian_lam1
Organizer
May I know anyone had change the value "storage source"? Does it change the database source from SQL server to the fat files directory define in CAS configuration?
I can't find detail information from the manual. Any comments are appreciated. Thx
Sylvian
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Sylvian,
It adds ability to drill down into aggregated clients or servers and retrieve detailed data by default cut to last 2 hours to not to blow up DMI.
The workflow assumes you will go to Sites, find users aggregates to a location, CIDR or AS and drill down into full list of clients.
