DNA 12.3 and BDC with IE 11
rucavalheiro
Inactive
I can't get the BDC option enabled from the Capture Trace screen.
In 12.2 there's a section in the release notes explaining how to support IE 11. This section disappeared in 12.3.
Any experience around this topic?
 Rui Cavalheiro
4 REPLIES 4
ulf_thorn222
Inactive
Hi Rui
if you are fishing around for SSL data you might want to apply the 12.3.528 patch as the SSL decode had some shortages prior to that.
Thanks Ulf. Good to know.
tomasz_szulist
Inactive
Hi Rui,
Unfortunately, as of now, BDC does not work with IE11. It's not specifically related to 12.3 (nor any previous version). It worked with IE11 GA. Apparently one of recent updates for IE11 must have introduced new security enhancements that prevents BDC from intercepting data properly. The problem has been published as known issue: DNA 12.3 Known Issues#DNA-09. I am afraid it's not a matter of hotfix, so I would not expect it before next release (which is planned this fall). In the meantime, please check SSL decryption for available HTTPS traffic analysis options.
Tomasz Szulist
Ok Tomasz.
Rui
