Does changing baseline mode affect baseline alerts?
cosmin_gherghel
Dynatrace Pro
Dynatrace Pro
I want to change the baseline mode from daily rolling to day of the week. Before I make the change I am wondering if the will have any affect on any alerts that use baseline value as a condition. Are the new baselines created on the historical data or will be they be created from when the change was made?
roman_rycaj
Helper
Baselines distributed over hours, weekdays, and weekends are being calculated over several weeks of measurements. When present baselines have been found as a distribution over hours (rolling) and CAS has been imposed to find day-of-the-week baselines, next baselines will be found as a distribution over hours and days from measurements quantifying last weeks. It impacts alarms from a moment baselines will be referable, usually a couple of hours after a midnight.
