Does the High speed AMD work with Open SSL, or do we need the physical SSL Card?
bcox2
Organizer
I cannot find anything that says do not use open ssl with high speed, so wondering if anyone knows the answer to whether open ssl can be used with the new High Speed AMD.
jaroslaw_orlows
Dynatrace Pro
Dynatrace Pro
Yes, High Speed AMD works with Open SSL.
