Double filtering on metric
nva_dt
Dynatrace Pro
Dynatrace Pro
Hi team,
I recently learnt how to double-filter on a dimension using the benchmark data tab. I was wondering if it is also possible on a metric?
For example, client bytes > 1MB and client bytes < 2MB
Thanks, Nic
avner_san2
Inactive
Hi Nicolas,
You can add your metric (client bytes, in your case) and then click in the + option to add the filter. Your configuration will be something like that:
Hope that helps,
Avner
