Early access programs for IBM MQ transaction flow analysis and consolidated Oracle EBS performance dashboard
Karolina_Linda
Community Team
Community Team
Hi All!
We encourage you to take part in the new Data Center RUM early access programs focused on IBM MQ transaction flow analysis and Oracle EBS performance measurements.
  • The
    new DC RUM decode for WebSphere MQ allows you to name MQ transactions
    using text extracted from the MQ message content and follow transaction
    execution across multiple managers and queues.
  • For Oracle
    Applications monitoring, DC RUM now allows you to run Forms and HTTP
    decodes on the same server and port from the same AMD.
Sign up today!
If you have any questions, don't hesitate to ask - this forum is here for you.
Best Regards,
Karolina
Keep calm and build Community!
matt_evanson1
Organizer
Will this only be for High Speed AMD's? Or available on regular 12.4.x AMD's?
Thanks!
Krzysztof_Ziemi
Dynatrace Pro
Dynatrace Pro
This is for HS AMD. In general - any new features we add these days, or any enhancements, go to HS AMD only.
