Ethernet Link utilization of remote location
sylvian_lam222
Inactive
I have a question regarding traffic analyze under DCRUM Enterprise mode.
There are multiple links between remote locations and local datacenter, we place AMD behind the router. Is it possible to identify the link utilization (all ethernet traffic) of each remote locations? If not, would netflow help on this case?
Many thanks.
Sylvian
ulf_thorn222
Inactive
Hi
Well - Yes and no.
First - if you have a "spoke/star" network layout where all traffic from the remote locations go to a central site you will be able to do what you ask.
But if you have a MPLS network f.ex. or many different connections going to other locations than just your central DataCenter then you will not be able to do so - Unless - You do as suggested yourself, use Netflow.
sylvian_lam222
Inactive
Hi Ulf,
Thanks for your reply.
Yes, totally agree.
Sylvian
