Hardware Health not displaying in RUM Console
bob_zins
Helper
I have 3 AMDs and 1 of them is not displaying the Hardware Health in the RUM Console That AMD is running 12.4.6. Any suggestions on what I need to do.
Tomasz_Lisowski
Advisor
Is it simply not displaying Hardware Health section for the AMD or hyphens? If hyphens, then hover the mouse over the hyphen to see tooltip with details. Note that you will see Hardware Health for AMD only if AMD is added to CAS as a datasource.
The Hardware Heath section is missing completely. The data feed for this AMD to the CAS is currently off, so once its enabled again I will verify if the Hardware Health section appears. Thank you for the response.
