How do I create an Alert for a Sequence Transaction
bob_zins
Helper
I have a few Sequence Transaction and I was wondering if I can create an alert for them.  In the "Monitored Dimensions" of the alert configuration, there is an option to choose Transaction, but I believe this is an application transaction
tomasz_nowakows
Dynatrace Contributor
This was already raised here: Alert for Sequence Transaction (Detail), let me present a copy:
Sebastian Kruk
When you use "Synthetic and sequence alert" the dimensions Transaction and Application will handle the data you look for.
See example for Sequence Transaction defined below:
We defined alert as follows:
In the alert log you see that application and transaction dimensions return correct values:
I hope that helps.
