How elliptic curve ciphers are going to impact DCRUM’s ability to monitor application performance?
ymaaa
Organizer
These ciphers do not use the server’s private key to
generate the primary secret and thus remove DCRM ability to decrypt that traffic
when captured on the wire. Do we have further plan to support it?
YC
raffaele_talari
Inactive
Hi Yc Ma,
I've already ask the same question to Dev and there aren't further plan to support it, the reason is the effort to develop the solution and the need of an agent (or more than one) to handle the "dynamic decryption" of the ECDHE suite.
Hope it helps.
Ciao,
Raffaele
