How to check specific monitoring point traffic at amd side?
shashi_dasi
Inactive
Could anybody help me with the right command to run at AMD side to fetch the monitoring point(webserver/loadbalancer) specific traffic.
Thanks In Adavnce.
Regards..
Shashi
4 REPLIES 4
chris_v
Dynatrace Pro
Dynatrace Pro
Not sure what you are asking about specifically.
Do you mean a packet capture? Statistics on traffic for a certain server?
shashi_dasi
Inactive
Hi Chris,
Yes, you are correct, packet capture as well statistics of certain server.
Babar_Qayyum
Leader
Hello Shashi,
I guess you are looking to get the tcp dumps for a specific server and port on a specific interface.
If this is the case, you can use the below command.
tcpdump host
142.182.28.26 and port 80 and tcp -i eth2
Babar
ulf_thornander3
Inactive
