How to create a Transaction Business Unit based on SQL Table names?
tdavison2
Organizer
Hello everyone,
I am trying to create a Transaction in DCRUM Business Units, however, I can't figure out how I can filter on a SQL table. If it is not possible to filter on a SQL table, I can see all of the SQL queries for that table in Expressions, but, I can't figure out how to select multiple Expressions for one Software Service.
Thank you very much for your help,
Tom
BabarQayyum
Leader
Hello Tom,
Use query monitoring to specify queries that are always reported regardless of their frequency or performance (regardless of whether they comply with query auto-learning requirements).
You can either specify a literally given query or use a regular expression that the query will match.
Have a look on the below link:
https://community.dynatrace.com/community/display/...
Babar
Hi Tom,
Instead of selecting multiple expressions, you can add multiple rules to a single business unit.
Tomek
