How to define max concurrent request in DMI
gianluca_dermil
Participant
I need to increment the maximum concurrent DMI request. The default value is 25 but I would know if I can configure a highest value . How can I to define the max value to set?
Tks
Gianluca
6 REPLIES 6
Babar_Qayyum
Leader
Hello Gianluca,
Could not understand the question. Would you mind to elaborate a bit more for our understanding and maybe the solution you are looking for.
If possible you can also share the screenshot for more clarity.
Babar
gianluca_dermil
Participant
Erik_Soderquist
Dynatrace Pro
Dynatrace Pro
I do not know what the variable will support as a maximum number in the configuration, but having worked with this setting with multiple customers, a practical upper limit seems to be 35-50.
Please bear in mind that the more parallel reports are allowed to run, the more risk there is of impacting overall performance, which can manifest in processing delays.
-- Erik
OK! I got it . thank you so much
Gianluca could you share some example of reports where you need to extend those values? It seems like you are running quite a big reports. Maybe there is a way to simplify them.
For example reports like "Metric charts" have been built to reuse the same query across multiple charts - this way database / cache is only queries once, while we render multiple charts showing only selected metrics in each chart.
I can jump on a call with you to analyze your use case in details.
gianluca_dermil
Participant
thank you all for the clarifications
regards
Gianluca
