How to reset transaction in AMD 2017
smunawar
Inactive
We have an AMD 2017 installed in the RHEL7, currently we are doing testing and verification on the AMD. Once completed then we need to integrate with CAS & ADS, question is there any command to reset testing transaction in AMD and make the AMD as fresh as possible.
Munawar
Babar_Qayyum
Leader
Hello Munawar,
May be there is better way but you can remove all the files from the directory /var/spool/adlex/rtm.
Also you can stop processing data from the below location.
http://Your_CAS_IP/DiagConsole#/diag/DATA%20PROCES...
Babar
smunawar
Inactive
Thanks @Babar Q., working fine for me.
