Http light documentation not correct?
henk_stobbe
Mentor
When reading the documentation, about content type monitoring the text is identical al for the regular http decode. But instead I can not add Content types but only exclude, also the filtering out is empty. Reading the documentation it should be the same as for http decode filled with .css .htc .gif etc...
Why the difference?
5 REPLIES 5
Babar_Qayyum
Leader
Hello Henk,
By default content type monitoring and filtering out pages will be empty for the HTTP Express analyzer on the global level and you can use the 'Add' button from the right side.
For the regular HTTP analyzer you will find the same on the global level like below screenshot.
Open configuration of the AMD > Global > HTTP > Content Type Monitoring
You can also specify the content types on the software services basis if you don't want to use a global setting, so just un-check the 'Use global values' and add your own.
Babar
henk_stobbe
Mentor
Hi Barbar,
I have added Filtering out pages, and that works for me, thx.
Do you know the object recognized as pages in the http light is empty, and you can only remove.
so http light only has text/html I assume?
KR Henk
Hello Henk,
Check the following link:
https://community.dynatrace.com/community/display/DCRUM124/HTTP+Express+-+Content+Type+Monitoring
Babar
henk_stobbe
Mentor
Hi Barbar,
FYI:
For light decode:
For normal decode
Thx for your replies!
Hello Henk,
I had gone through with the following documents link and found that almost everything is similar except the software service and URL configuration which is available only for the regular analyzer (HTTP).
https://community.dynatrace.com/community/display/DCRUM124/HTTP+-+Content+Type+Monitoring
Our AMD version is 12.3.8.6 and I took the below screenshots as reference where we can see the difference while adding the 'Content-Type' for both analyzers.
It means we can not enable the URL auto-learning and other options in the HTTP Express but the document is kind of a copy / paste for both analyzers settings.
Babar
