I need Others "RESOLUTION STEPS" between 5mn and 1 hour
Hello Community,
Please let me know, if it is possible, how to configure DMI reports to get others RESOLUTIONS between 1 period and 1 hour.
I need, so i would appreciate the following :
15 mn
30 mn
at least
and 10 mn would be great.
Attention Please, i am not speaking about to have for example extra "Last 15mn" preset Time range
NO I WANT, I AM SPEAKING ABOUT ... NEW RESOLUTION STEPS
That is,
once time range is selected, either through Preset or Relative or Absolute TAB
you can choose the resolution step by dropping down the resolution list where currently you can find ...
1 period
1 hour
6 hours
1 day
1 week
1 month
And what i want is ... for example :
1 period
10 mn
15 mn
30 mn
1 hour
6 hours
1 day
1 week
1 month
That is,
i want 6 steps per hour if i choose 10 mn resolution option
i want 4 steps per hour if i choose 15 mn resolution option
i want 2 steps per hour if i choose 30 mn resolution option
Hope this is possible.
Many thanks in advance
Regards
P.SARGNON
3 REPLIES 3
dariusz_kalita
Dynatrace Helper
Dynatrace Helper
You can add the following lines in new file for
example in reportTime-custom.properties.
The file will survive upgrades and is suitable for current and future versions.
### for versions > 12.4
ReportTime.15m.name=Last 15 minutes
ReportTime.15m.group=Current
ReportTime.15m.class=adlex.delta.dmi.data.ranges.DMIRange4Advanced
ReportTime.15m.position=11
ReportTime.15m.editable=false
ReportTime.15m.allowedResolutions=PERIOD
ReportTime.15m.periods=15
ReportTime.15m.periodsUnit=min
ReportTime.15m.isNow=true
Restart is not needed (server tracks file
modifications). You can also leave modified file because the definitions are
the same.
Solution for older versions however will not survive upgrade. i..e
after any installation (for example service pack) your new time range
disappears.
### old format (<= 12.4.*)
ReportTime.15m.basedOn=PROCESSED_DATA
ReportTime.15m.roundedUnit=PERIOD
ReportTime.15m.shiftCount=-15
ReportTime.15m.shiftUnit=MINUTE
ReportTime.15m.periodLength=15
ReportTime.15m.periodUnit=MINUTE
Please repeat it accordingly to all required time frames.
Darek
I’m happy to let you know that we are working on additional resolutions at this very moment. I will check our extended list of new resolutions that will be delivered in 2018 release against your list tomorrow and will let you know on our progress.
Currently we work on supporting: 1 min, 2 min, 5 min, 15 min, and 30 min resolutions. Would those 3 additional resolutions help?
