Identifying RPC under TDS monitoring
tarjei
Organizer
For normal queries in TDS monitoring it is possible to use regular expressions. How can I do the same for Remote Procedure Calls? (RPC)
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Have you tried using regular expressions
under Monitored Queries?
Well that kind of beats the point, because that would presuppose that I knew how the RPCs looked like. With SQLs you can see them, and some of them start aging etc. This is not the same with RPCs in my experience.
