Integration between DC-RUM and Nagios or Check_MK
FranciscoGarcia
Dynatrace Organizer
Dynatrace Organizer
Hi all
A customer is trying to get alarms from DC-RUM to Nagios or Check_MK consoles They are trying to use SNMP for this, but are open to any suggestions if we have other ideas.
At this point, they have done some testing and are able to send and receive traps but they can't seem to be able to distinguis when an alarms is created and when it is canceled so they can't have a different tratment when the alarm is created and when it is cleared
I am no SNMP expert, but will gladly add any information requested, Is there some way to diferentiate these?
Thanks in advance
Fran
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Francisco,
Have you resolved it?
FranciscoGarcia
Dynatrace Organizer
Dynatrace Organizer
Hi Adam. Thanks for your help, this is no longer an issue.
