Is configured? Metric Not Available
genesius_jarom1
Organizer
I am manually copying the dimensions and metrics from a DCRUM provided (?) report, and I cannot find the metric "Is configured?"
It is also needed for the Result Display tab.
Thanks and God bless,
Genesius
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Genesius,
The "is configured" metric is used
in some out-of-the-box reports, but is hidden on purpose.
It serves a special purpose and only works within a very specific set of
dimensions.
That said, manual copying is probably not the
best way to recreate a DMI report. Why not save a copy or use the export/import
functionality?
There are many petty things in the out-of-the-box reports which are either
easily missed by a user, or simply unavailable for them.
genesius_jarom1
Organizer
Afternoon Adam,
I have to manually copy the report dimensions and metrics because the sections are from drill-downs of an out-of-the-box report. Tiers on 1st page; drill down to Servers and Operations on a 2nd page; etc. Drill downs will not be available; because this report will be emailed as a PDF to stakeholders.
This goes back to my post on Several Report Questions.
Genesius
