Is it possible to hide data filters (based on metric) when exported to pdf report?
martina_resutik
Inactive
We have set of reports setup to filter based on the data:
e.g. application health index above specific threshold and we need the value to appear on the report. Additionally we would like the filter not to appear in the exported pdf report. Is there a way to filter this out?
Metrics do not have any option "Filter mode" as a dimension does...
Thank you
Kind regards, Martina
We plan to enable to control visibility of metric filters in reports. With that you could hide them and they would not show in the PDF export. I'll let you know once we have that implemented.
