Is it possible to integrate SCOM and Solarwinds with Compuware APM products (Enterprise Portal, BSM, ...) ?
dariusz_baromsk
Inactive
Sorry, I didn't find appropriate place to post this question:
I think that there is no easy solution, but maybe I'm wrong...
4 REPLIES 4
ulf_thorn222
Inactive
Hi Dariusz
Yes - You are wrong (smile)
As you point to, ther is a very versatile piece in the APM portfolio and that is the BSM. It can basicly pull or receive data from any system and correlate that with metrics from the APM suite. Have a call to your local Rep and see what they magic they can do!
dariusz_baromsk
Inactive
Thank you Ulf.
Now I see in the documentation how a third party data can be sent to BSM....
Just one question more (sorry, but our BSM knowledge is very poor).
I see something concerning MS SCOM in Connections Panel of BSM Connection Management.
Does this mean that there is already SCOM integration provided, something working "out of the box" ?
Kind regards
Hi Dariusz,
You are right (smile)
BSM has an out-of-the-box adapter for integrating with SCOM. Please see page 213 of this document below for additional details on SCOM Adaptor:
Harshal.
dariusz_baromsk
Inactive
Thank you very much.
Kind regards
Dariusz
