Is there a shutdown sequence for DC Rum?
bill_scheuernst
Organizer
In order to work on the console and CAS database, we need to shutdown DC Rum. Is there a correct procedure to do this?
david_n
Inactive
Hello
Bill,
When
I look at the upgrade guide for DCRUM they have a list of the order to upgrade
each component in DCRUM. I have listed the relevant steps below. My suggestion
would be to reverse that order while you shutdown DCRUM (replacing upgrade with
shutdown/start as needed).
  • Upgrade the RUM Console
  • Verify RUM Console
    upgrade
  • Upgrade the database
  • Upgrade CAS or ADS
  • Verify CAS or ADS upgrade
  • Upgrade the AMD
  • Verify AMD upgrade
  • Upgrade TCAM
  • Upgrade Enterprise
    Synthetic
https://community.dynatrace.com/community/pages/viewpage.action?spaceKey=DCRUMDOC&title=Upgrade&_ga=2.129028876.1491414174.1502116810-1202939376.1500917309
David Nicholls
