Is there a way to clear a system status warning?
bob_zins
Helper
Is there a way to clear a system status warning? I'm receiving a warning message regarding the Daily report generation. "Scheduled tasks executed successfully but long at 5/9/18 05:54. Execution time: 4h 57min 28.180s. Timeout: 6h" I have received calls from some of my users regarding the message and if its a problem. I would like to clear the message so it does not distract my users.
tomasz_nowakows
Dynatrace Contributor
Hi Bob,
I believe you'll find https://community.dynatrace.com/community/display/... helpful.
Best Regards,
Tomasz
